Salta al contenuto principale
Rilasciato il 16 settembre 2016. Modello 1660, 1778. Disponibile come GSM o CDMA / 32, 128 o 256 GB / Rose gold, gold, silver, black e jet black.
2264 Domande Visualizza tutte
Replacing A1660 logicboard with an A1778 on an iPhone 7
Is it possible to replace an A1660 motherboard, with an A1778 one? I destroyed the baseband pad, on my phone’s A1660 logicboard and i need a cheap replacement. The only thing i found, is a model A1778 logicboard. Will the replacement work?
Questa è una buona domanda?
Punteggio 1
1 Commento
A1778 ka motherbord ha?
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi Yannis!
Physically, the board will fit fine. Bear in mind however that the models are differentiated primarilly by which modem they use - Qualcomm or Intel. So, it should fit just fine. I would also expect it to work fine, but there may be some performance differences. You’ll also want to be certain that the replacement board comes with its original home button or your Touch ID will not work. Finally, be sure that the replacement board is not iCloud locked or you’ll have a whole new headache.
Cheers!
Joshua
Punteggio 1
2 Commenti:
Thanks a lot Joshua. Your answer was pretty informing.
da
You bet! Glad to help!
da
Aggiungi la tua risposta
Yannis sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 669
