Why is a green key flashing in my dash
car crank but want start
Questa è una buona domanda?
Hi,
The “green key” light is an indicator for the car’s immobilzer system.
Here’s an image taken from a 2004 Honda Accord owner manual that explains what the problem is when the light is flashing.
(click on image to enlarge for better viewing)
This step is not working
The fuse is not okay...
Worked thanks fuel was okay thank God!
How did you solve this?
The icon of a green key in the instrument panel is normal although many of us never notice it. The green key will come on when you turn the ignition key to the start position. If everything is working correctly the key will blink once and go dark and the car starts. Where you insert the ignition key there is a component around the key hole called an Immobilizer. It is part of the anti-theft device in the vehicle. It’s job is to read the chip in your key fob ,,, if it’s the right information for that particular car, the Immobilizer will inform the car’s onboard computer and the vehicle will start. Every vehicle has its own unique code and is identified by the vehicle vin number. If the code is wrong or the reader is not functioning the computer will shut the fuel and firing systems down and the car will only turn over but will not start , some vehicles will crank up but then immediately shut off.
If you disconnect the immobilizer component will the engine turn over/start or will it completely shut it all down?
@D MyVoice
Open the keyfob and remove the battery.
Then clean the board in the keyfob using Isopropyl Alcohol 99%+.
When it is dry, reinsert the battery and check if it now works OK in the ignition.
My key does not have a opening I have no buttons on my key so I know its not the key doing wrong .my car turns over it might take 3 attempts then it starts but it is getting harder to start I have looked up a lot of stuff to see what the problem is .I guess a trip to the meachinc
Check your fuses it may cause the immobilizer flash light to on frequently..
Ultime 24 Ore: 7
Ultimi 7 Giorni: 74
Ultimi 30 Giorni: 365
Tutti i Tempi: 77,536
1 Commento
my honda civic car key fall in water by mistake after that green key flashing that time what should i do
da D MyVoice
