Salta al contenuto principale
Released in October of 2003, Sony's Cyber-shot DSC-T1 is an ultra compact camera with many great features all in a package about the size of a deck of playing cards.
6 Domande Visualizza tutte
Misplaced Pin on Sony DSC-T1 Repair
Hi Great guide on repairing the DSC-T1's components. When I opened the front cover a small pin fell out. It is about 11mm long and the shaft is about 1mm in diameter. I do not see it pictured in any of your photos and I can't find where it goes. The camera seems to work without it, but I'd really like to know where it goes.
Thanks for your help.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
4 Risposte
Soluzione Prescelta
Sean Mann I placed the complete level 1-level 3 service manuals for you to download. It will show you everything you ever wanted to know about your camera. May be you find the "spare part :-) " and its location. Good Luck
Level 1
Level 2
Level 3
Punteggio 3
3 Commenti:
Thanks a ton man!!
da
You are welcome ;-)
da
Thanks to Old Turkey I can tell you that it's a "lens pin" and it goes into the lens/CCD assembly, just under the one motor.
On the other hand I can't tell you what it does. Looks like it just lies in there loose, doesn't hold anything, doesn't touch anything (except the front and back covers, looks like).
All I can think of is maybe it's a spacer to keep the body from denting in the middle. Anyway, mine's in and all is good. Thanks Old Turkey!
da
Have you foumd where this goes - same problem?
Punteggio 0
1 Commento:
is it a pin for the strap to be tied to?
da
it looks like the axel rod with spring of the battery door. i have this camera to repair the ccd sensor. everything its working but i can´t get images comming through the lens thanks for the ifixit site
Punteggio 0
I have a Sony DSC-T1 Cyber-shot - Digital Camera - 5.1 MegaPixel - DSC-T1. I haven't used it in a year. I just connected the cable charger to get it to work. ASll I'm getting is a window with the clock set options. I've reset the camera. However, I'm unable to use all other functions. Do you think I need a new battery?
Punteggio 0
Aggiungi la tua risposta
Sean Mann sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,779
