Salta al contenuto principale
Larger version of the Nintendo DSi, released March 2010 in North America. Most repairs are accomplished with only a screwdriver and prying tools.
157 Domande Visualizza tutte
I've broken the DSI motherboard power connector!
I recently bought a "for parts" DSI off of Ebay. The lower screen was broken, but I'd replaced a DS lower screen and figured I could handle it. I used the instructions on this website to begin the disassembly of the unit, when I got to the point where you disconnect the power cable from the mobo (step 9) I ran into a problem: the entire connector, not just the cable, came off the mobo. Is there any way to reconnect the mount point for the power connector or is this a matter of suck it up and send it out to a repair tech? I'm going to look at under a magnifying glass and hope I can solder it back on, but I'm not certain that will work. Any suggestions most appreciated.
Questa è una buona domanda?
Punteggio 8
5 Commenti
As a side note, I've noticed what appears to be either water residue or some type of glue on various parts of the motherboard. also, before the teardown, the unit did power on when plugged into a wall charger. It appeared to just be a broken LCD was the issue with this unit. (but I could be wrong)
da
AdamMcinturff, is there any chance you can post a pic of the damage. I think that there might be a way, if you are pretty handy. Of course you can also send it off to get it repaired, however make sure that you get a good cost estimate in order to not spend more than a replacement DSi would cost.
da
Just to update, it is quasi-repaired. I used alcohol to clean the motherboard and used; a flashlight, a soldering pencil, and a magnifying glass (at this point there was someone else helping, let's face it my soldering skills are only so-so) and we ever so gently soldered some extra wire directly onto the mobo and then soldered that to the connectors from the power supply board. sadly the case wont close completely (to much wire I suppose) and occasionally the thing acts as if the up or down button is constant on. any idea where I can find thinner wire?
da
Check a electrical supply house for thin wire. Good luck. + for your effort.
da
+ I second that
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
replace the power button assembly or the motherboard.witch ever one
Immagine Nintendo DSi XL Scheda madre
Guida
Sostituzione della scheda madre Nintendo DSi XL
Difficoltà:
Moderato
20 - 30 minutes
Immagine Nintendo DSi XL Power Board
Guida
Nintendo DSi XL Power Board Replacement
Difficoltà:
Moderato
15 - 30 minutes
Punteggio 1
Hi, have the same problem.
I soldered red and black wires directly to two very little metal pads placed just on the motherboard, to the left, i mean nearer to the wifi module. But I got no result: console screen makes a little flash and then got off. I suspect there might be another connections to be made but as i've broken the whole mobo dc connector can't imagine what else.
Thank you.
Punteggio 0
3 Commenti:
(I know this is old but someone might need the info)
I did the same thing but soldered underneath the board which did work, trouble was the case didn’t fit comfortable.
da
@void west
Can you please show a picture? I'm having real trouble with this problem and it would be GREATLY appreciated!!
da
I have the same problem and I have no idea what to do going forwards. Do I just solder the connector back on the board or do something else?
da
Aggiungi la tua risposta
AdamMcinturff sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 27
Tutti i Tempi: 8,696
