Salta al contenuto principale
Rotary tools got plugged to 220v system and it only supports 120v.
American tool Dremel 4300 voltage 120v got plugged to European electrical system so 220v and got knocked out. Any possible solutions??
Thanks peeps.
Laura!
Questa è una buona domanda?
Punteggio 2
1 Commento
i've used 110vl in 240vlt in oz Twisted the 2 pins angled so they fit in au socket and it worked -to test in 240vl maybe yours was faulty ? some tools have a reload cell fuse inside you'll have to open it to see or get a blow up of the item from the c/o or a site google it :) p/no
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
LAura Scanavacca  I would suggest you take it apart and check the circuit board. It would stand to reason that this is where the damage occured. Use something like this guide Dremel 4000 Electrical Assembly Replacement to get to it. Post some images of what you find with your question. That way we can see what you see. Use this guide Aggiungere immagini ad una domanda for that
Immagine iFixit
Guida
Difficoltà:
Molto facile
2 - 5 minutes
Immagine Dremel 4000 Electrical Assembly
Guida
Difficoltà:
Moderato
15 minutes
Punteggio 3
Aggiungi la tua risposta
LAura Scanavacca sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 15
Tutti i Tempi: 893
