My laptop is over heating
So my lenovo is constantly hot and the fans are running full speed, i am wondering if the cooling system needs cleaning or is there any fix to the overheating issue because the laptop recently started getting this hot
Questa è una buona domanda?
5 Commenti
Hi I got a brand new lenovo touch screen .. it heats up the once turned on i don’t know why i feel so bad and i don’t know what to do it is brand new .. still fan works with it’s full speed once I switch on and it heats up from bellow and above as well
da Duaa Alherbawi
@Duaa Alherbawi ,
What is the model number of the laptop?
Does the fan continue to run at high speed even if you just turn it on and don't do anything on the laptop for about 5-10 minutes and then check if it slows down?
da jayeff
Thank you for your reply sir, yes once i turn it on and it is brand new Lenovo touchscreen but i dont know the model name ..
da Duaa Alherbawi
@Duaa Alherbawi ,
The model number should be on the information label that is on the bottom (or underneath) of the laptop
da jayeff
THank you so much for your patience the model number is 81TK touch screen
In this laptop there is no way for me to work while it is on charger as it heats up massively .. I must charge it first then work else the heat wont allow me to touch it ..
da Duaa Alherbawi
