Salta al contenuto principale
Tutto quello che ti serve per riparare stesso il tuo iPhone! Dal nuovissimo iPhone 15, fino all'iPhone 2G originale del 2007, iFixit offre guide di riparazione gratuite e informazioni sullo smontaggio per ciascun modello di iPhone, oltre a fornire le migliori parti di ricambio, strumenti e consigli della galassia.
36478 Domande Visualizza tutte
Nand Memory Dump socket available?
hey guys.
ive been spending the last couple weeks fine tuning my SMT skills, and i was wondering if there is a NAND reader for iphone chips. ive gotten pretty good at successfully removing them without any damage, and i would like too invest in a memory dump socket to retrieve data off of the device for clients. I see a bunch of test sockets, and iOS install sockets, but i can find anything for memory access. is there anywhere that sells read/write friendly sockets?
if they dont exist, i wouldnt mind reasoning behind it, or if there is a project on the way.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
I don't think you'll be able to read data off these NAND chips that come from iPhones because the data on them is encrypted and the key to decrypt them comes from the CPU which as far as I know of nobody has managed to retrieve the decryption key to read data off the NAND.
Mostly the NAND readers are used to backup or write partitions / file system so that replacement or donor nand chips can be used on a logic board.
Punteggio 2
2 Commenti:
how abouts do data retrieval specialists retrieve data from dead phones? im looking into the procedure, but theres nearly nothing online. Ive been told they take the chip off, and solder it into some form of dongle, but i cant find information on that at all.
da
I've been told otherwise where they transfer the main chips required to be together with NAND and solder them to a working board to get data off it.
If it was easy as getting it off chip via reading nand chip data off dongle I'm sure many others would have done this already and have a video on YouTube to prove it.
da
Aggiungi la tua risposta
Scott sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 738
