Salta al contenuto principale
A1708 / EMC 2978 — Lanciato nell'ottobre 2016, questo MacBook Pro entry-level conserva i tradizionali tasti funzione (invece della Touch Bar OLED). La versione function key adotta l'Intel Core i5 e 2 porte Thunderbolt.
216 Domande Visualizza tutte
Backlight only works at certain angle
My computed had a liquid damaged and I took it immediately to a repair shop and they cleaned the motherboard and it didn't had any rust or liquid damage. But now the backlight only works when the lid is open at less than 45 degrees. If i fully open the screen the backlight turns off.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Well you’ll need to replace the display assembly. Sadly because you had liquid damage Apple won’t service this system. If you hadn’t you might have gotten it fixed under warranty.
This is a known issue with the 2016 models many people got it replaced under the first year warranty as well as the extended AppleCare + warranty. Some folks who did not have coverage have been able to get it fixed under a warranty exception.
OK can’t cry over spilled milk.
Here’s the guide you’ll need to follow: Sostituzione schermo MacBook Pro 13" Touch Bar 2017 while this is for the touch bar models it’s the same for the function key model as well. And here’s the needed part: MacBook Pro 13" Retina (Late 2016-2017) Display Assembly
Immagine MacBook Pro 13" Retina (Late 2016-2017) Display Assembly
Prodotto
$454.99
Punteggio 1
1 Commento:
Thank you very much for your answer
It’s so sad to have this problem right after the liquid damage.
da
Aggiungi la tua risposta
Maycol Madrid sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 913
