Key not working on the Yamaha MOXF6 keyboard
Yamaha MOXF6 all B and E note not working. I tried to restart, but problem is still there. I tried everything with softwer and not resolved it?
Questa è una buona domanda?
Hi @pianoplayer ,
You may have a problem with the power feed to the keys.
You need to check the following:
Check that the cable plugged into the CN-704 connector on the KEY-IF board in the keyboard is fully plugged in, especially at one end, as the power feeds to the E and B keys go out from the board on pins 11-&12 of the connector.
(I hope I have this right as I’m not musical but the power for all the notes (keys?) goes through this plug. The power is +5VDC coming from resistors R703 to R714 on the board, I have marked the connector pins and resistors).
If the power is OK leaving the connector then check that the cable is plugged in securely on the CN1 connector of the 61H board in the keyboard.
Here are some images to show what I mean:
(click on images to enlarge for better viewing)
Here is a link to the service manual which may be of some help in showing how to gain access to the boards for testing.
Scroll down and click on the Download link to download the manual.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 600
