Salta al contenuto principale
The TI-84 Plus CE is a graphing calculator released in Spring 2015 by Texas Instruments. It includes a 2.8 inch color screen, USB port, apps, storage, and a 1200 mAh battery.
Display still on even when shut off?
When I shut off my calculator, the display still looks faintly on. How to fix this and will this have any implications?
Questa è una buona domanda?
Punteggio 0
1 Commento:
Hi, I don't know why your screen wouldn't fully shut off. What does it look like? Like the screen is trying to display things but the back light is off? If you take it into a dark room does the display still give off light?
da
Aggiungi un commento
1 Risposta
OK, you didn’t tell me any more info from my comment so I’ll turn it into an answer.
I believe it’s likely that your calculator really has turned off and your lighting conditions make it seem like it hasn’t.
To test if the backlight is still on, simply enter a dark room and see if there’s any light being emitted from the LCD.
To test if the LCD is still displaying things, but the backlight is off, just look very closely at the LCD, if you don’t see anything other than a black screen, then there’s nothing wrong.
If your LCD really is staying on, you can try to RAM reset or reinstall the OS. But I think you’ll end up needing to contact TI.
Punteggio 0
Aggiungi la tua risposta
07 21 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 273
