How do I fix the USB charging port on my ZTE Max XL cell phone?
My ZTL Max LX cell phone's USB charger port is broken.
Questa è una buona domanda?
Hi @khimmenger
I would suggest you to dismantle the phone till you see the charging port module.
Inspect the usb c charging port module on how bad is the damage. If circuit traces has been ripped out, it would be good if you can get that replacement module.
Else if it is just the damaged usb c socket and if you have some knowledge on micro soldering and misc, you can consider by just replacing the defective usb c socket.
The usb c socket replacement can be obtained either ebay or aliexpress... etc, but there is a catch, you need to compare it with pictures as much as possible before ordering, unless it has been specified as a replacement with your phone.
Good Luck!
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 767
