Salta al contenuto principale
Repair guides and support for your Samsung TV.
TV getting double image.
I have samsung led 32 inch TV. The my TV getting double image. I my TV model no is samsung ua32eh4000mxxs. please give right information about my TV so that I can repair my TV.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
sahebsah5  double images can be caused by bad cable connection from the T-con board to the panel
You will have to remove the back of your TV and check the cable by removing the cable from one side and see if the other side displays properly. Most likely a new T-con board may fix this. To verify my suspicion, post some good pictures of what your screen displays first. Then remove the back of your TV and post some good pictures of all of your boards etc. That way we can see what you see. Aggiungere immagini ad una domanda
Punteggio 0
Aggiungi la tua risposta
sahebsah5 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 22
Tutti i Tempi: 10,256
