iCloud. BackUp. Broken. Bugs
Hello, friends
I ask for your help. Here's the situation
ios 11.4 There is no criticism. But on May 19, he made the last BACKUP in the iCloud, the size of 790mb. Since then he persistently wrote to me, he can not make a copy, because of lack of space. But the nuance is that, since the last copy of my settings have not changed, so that he had something else to copy. That is, the last copy made on the 19th day should not differ from the one (which should have been done), for example, 21th.
I've rummaged in Google, there are standard cases for which I myself have the answer. I decided to wait for iOS 12, in the hope that a clean installation as a new phone will solve this problem. But nothing has changed. In this case, in the backup settings, the library and everything that can be large is turned off. That is, Ikeklade sucks only the Phone settings, Contacts and some data and several programs I need, even if you can not count, then 1 gigabyte there is hard to count. But why does he persistently consider 18.7 Gb and gives the problem of lack of space in the cloud.
Those support did not help. Their answer is either make a copy on the computer, or buy less space. But this is not the answer you want to hear from them.
The bottom line is that, I do not understand where he takes the 18Gb. I shoveled the whole phone. But I could not find them.
How to be friends?
Questa è una buona domanda?
1 Commento
FYI: Upgrading your iOS won't fix this.
da Dan
