Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1688/A1633. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 32, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
2690 Domande Visualizza tutte
Display assembly unresponsive after replacement
Replaced the display exactly how the guide said (disconnected the battery 1st). Phone is completely unresponsive after putting it back together. Screen is completely black and my PC and iTunes wont detect the phone. I tried putting the old screen back on to see if it would work but it did not. Although it was a pretty messed up screen so it could of just broke when being removed. Is there any way of seeing if i damaged the logic board in any way or something, not sure what to do here other than bring it to a repair shop.
Questa è una buona domanda?
Punteggio 0
1 Commento
Does it vibrate when the charger is plugged in? Or when the mute switch is flicked?
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
If the phone is completely unresponsive, you might want to go back and double check your steps (follow this guide) to see if you may have caused any accidental damage to the various flexes. Using magnification helps as it doesn't take much to cause issues.
Another way to test the phone to see if it is logic board related or not is to disconnect everything (screen, cameras, buttons) except the lightning port and battery (disconnect the battery first, then reconnect just before you test). Then connect it to an iTunes enabled computer. If the computer recognizes the phone, that means something you disconnected is causing the issue. Re-connect the modules one by one until you figure out which one.
If the phone is still not recognized, it is most likely the logic board although it could still be the Lightning Port or Battery. Depending on how much time and money you want to invest in troubleshooting, you could order replacement parts or have it looked at by a repair shop, preferably one that does micro-soldering.
Punteggio 1
Aggiungi la tua risposta
Bayley McGillis sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 30
