Salta al contenuto principale
A collection of guides and support to help with washer repair.
3478 Domande Visualizza tutte
washing machine leaking water from coin trap
My 14 month old (warranty expired) front loader Samsung wf45k6500av/a2 is leaking water from around the drain pump filter cap during the whole cycle.
Do you think I just need a new drain pump filter cap or is there a bigger problem?
And yes, the filter is clean, nothing seems to be lodged in the tubes either.
Questa è una buona domanda?
Punteggio 3
14 Commenti
And I’ve made sure the cap is on correctly and tight. But still the water leaks.
da
I have the same issue
da
My Samsung has just developed the same problem. I am currently seeking a new O ring for the seal although the original O ring does appear to be fine.
da
Any update on this? I’ve developed the same issue
da
I dont think I have ever been so tempted to write hate mail as I am right now to the engineer responsible for that leaky child proof cap.
da
Mostra altri 9 commenti
Aggiungi un commento
16 Risposte
Risposta Più Utile
Hey everyone,
I removed our filter to clean it the other day and like many of you when I re-installed it I had a leak.
FIX: There is a notch on the bottom of the filter, this has to line up with a small tab inside the filter housing or you will not get a seal and will have a leak.
Here’s a shot of the notch. I found no need to over tighten or replace the seal once I had this lined up as my leak stopped.
Punteggio 8
8 Commenti:
how do you orient the notch when you go to put the filter back ? upright like the picture ? .... or ??? please help as mine is leaking now too .... just took it off for first time because I got the '5E' code and it had some stuff in it .... go figure ....I washed some carpets ... man what a PITA to get it off !!! holy eYikes ....can anyone also answer me .... if I spend the $$ for the NON childproof part above..... does that help ??? it seems making that 'improvement' ..... actually FUBAR'd the ability to screw it back in correctly ..... or am I wrong????
da
This tip worked for me, stopping the leak without having to replace the cap. The tab inside is on the bottom to the left, the notch is pretty wide so lining it up isn't a problem. Something else to note is that the small square tab on the cap should hit up against the stop on the side when the cap is fully tightened.
I still think the child proof cap is an unnecessary piece of junk, and just makes everything more complicated than it should be.
da
Matching up the notch did the trick! Thank you!
da
I matched up with the notch after cleaning and it's still leaking no matter how much I tightened. The O ring isn't damaged at all no cracks, no cuts, nothing but it still leaks. Please help!
da
Thank you so much! I had a massively hard time getting this thing off in the first place, and am also very thankful I checked to see if it was leaking before I ran a full load!
One tip I did notice, the cap will start clicking before it is all the way screwed in, if you put some pressure on the outer rim (I was wearing gloves) as well as the handle in the center it helped to engage the thread and actually close the seal.
Thoroughly frustrated that the manual just says ‘screw it back in’.
Thanks again!
da
Mostra altri 3 commenti
Man handled it with pliers to get the leverage!! Pushed and turned right till stopped turning smoothly. I had originally tightened till it started clicking, so thought was on all the way. NOPE!!
You have to push in like heck, just get mad enough, you fine the strength, lol!! Turn right till stops turning smooth and clicks again.
holy mother of
Punteggio 3
2 Commenti:
Yep this worked for me too!
da
I hate , hate , hate everything about this washing machine from the nasty door seals that are impossible to keep clean, to the pump filter cleaning location and constant issues with leaking ,to it at random refusing to rinse and spin a load on certain cycles. I am a great grand mother and at my age and with reduced eye sight having to lay on the floor to struggle to clean and replace the filter is guaranteed to ruin my day.
da
Hi @kellyrich1123 ,
Looking at the 2nd video posted above, it appears as though there is a black rubber “o” ring under the screw cap which provides the watertight seal, when the cap is screwed on tight.
Check that it isn’t split, cracked or worn, creating an imperfect seal, when the cap is screwed on, so that the water can get through.
Punteggio 2
3 Commenti:
This contraption is THE WORST. SOLUTION for us us to line up the notch as mentioned above but start turning it counter clockwise until it clicks in and then clockwise to lock. Mary mother and joseph i want those hours back .....
da
I can think of some other words to say but they're too rude to write this is the most frustrating setup I've ever wasted my time on thank goodness for these posts now I can go to bed
da
I have a stacked front load dryer and Pinnacle washer in my travel trailer; although nothing is stuck in the coin trap, the trap fills with A LOT of water when doing a wash cycle. If I don’t manually empty the trap after each load, it will eventually leak out on the floor of my little laundry closet🫤I read all the comments above, and finally tried the “turn counter clockwise until it clicked” method which appears to have worked with the trap lid👍🏻Is the trap still going to fill with water during wash, and not empty from the trap by end of the wash cycle, leaving me with the crazy task of trying to empty water from the trap without ending up with water all over the little closet floor…?
da
I ordered a replacement (without the child proof knob which I believe was preventing my filter from tightening all the way). The part that I order which fit for my washing machine was: DC97-16991A. The part that is “supposed” to go there(the one with the child proof knob) is part number: DC97-16991B, I am assuming the “B” is for the child proof knob version.
Samsung DC97-16991A Assembly Filter https://www.amazon.com/dp/B01AQHQOTM/ref...
Punteggio 2
2 Commenti:
I have the same problem, unfortunately I was not able to take off the filter because of the children proof knob. I m getting mad because of that knob!
How did you do to take off the knob ?
Thanks
da
I had to use pliers and put all my weight on it while turning. It's a true pain in the ass.
da
FIXED!! :D Found the solution!!!! I had the exact problem. Which was extremely aggravating. Out of my rage, I examined the filter and cap thoroughly and there wasn’t a single problem with the part. So thinking to myself there is no freakin way this shouldn’t seal… so I went back to the dumb washer and man handled the cap with all my strength and BOOM! Problem fixed. I guarantee you aren’t tightening the lid enough. So call your husband or man around the house and ask them to show off their brute strength bc that’s the issue.
P.S. I called Lowe’s hotline and ordered the F-ing replacement part which was none refundable before I fixed it. FML
Punteggio 2
2 Commenti:
Thank you so much for this! I had to get pliers bear alley weight while turning and it was fixed! No more leaking!
da
This worked for me as well, thank you!!! I was giving up!
da
In addition to @jayeff excellent answer, I remember I used to use a gel to coat the O rings on my SCUBA gear to prevent them from leaking. This product may help insure a solid seal:
https://www.webstaurantstore.com/petrol-...
Punteggio 1
No, as much as you tighten it still drips. Samsung faulty part, the threads are too wide of a span to get a good seal. Poor quality.
Punteggio 0
1 Commento:
Hi,
Have you checked the washer that is under the cap to make sure that it isn't worn?
Highly unusual that the thread is the wrong size.
How much "play" is in there when you first go to tighten it up?
If worst comes to worst use a thread seal tape - example only to ensure a good seal.
da
For the child lock cap there is a tab on the cap itself. Your have to tighten the cap until that tab is locked against the very right-hand thread. Another way to say it is tighten until the cap (not the clicking) doesn't turn anymore. It will stop against the housing. You can't over-tighten it.
Punteggio 0
I tried all the listed methods about a year ago. My fix was I put plumbers tape on the threads of the cap. It worked great for about a year, but then started happening again. Cleaning what tape is left and trying again. That child proof cap is poorly designed.
Punteggio 0
1 Commento:
It is poorly designed. Did you try my fix above? I found that just going until it clicks isn't enough. It has to screw in until it stops against the plastic tab on the drain.
da
This answer is several years too late. My solution was to clean the o-ring and the surface that it contacts. Then I flipped the o-ring around facing the opposite direction from what it was. I didn't have to man-handle the filter back in to place, and so far there are no leaks.
Punteggio 0
If the notch in the basket is lined up, your o ring looks and feels good, and you're tightening it up as hard as you can and the child lock is clicking, and you still have leaks you can try this.
Take the filter out and notice that there is a little plastic cube on the outside of the threads just behind the o ring. Clip that off with some pliers or wire cutters. It's the thing that is engaging the child lock and stopping the threads from pushing too hard, but it's also stopping you from seating an old ish o ring.
Mark where the cube was with a little sharpie and install it again, go slowly and watch as it goes past where it would have stopped previously. You can safely go until it clicks one time, but go any farther and you risk damaging the housing for the filter and you'll need professional help for sure.
Punteggio 0
Punteggio 0
Try rotating it counter clockwise first after lining it up with the notches.
Punteggio 0
Every time I would clean my filter it would leak on the lower front left corner.
On the lower filter trap there is a screw on filter. After you remove filter to clean it. Place the cap back into the hole make sure to line up the filter trap groove which is on the back part of the filter not the front-then screw it in making sure its a level and tight fit. It can also help you to take a flash light look into this hole about three to four inches deep and you will see the groove to align the back portion of the filter catch.
If that doesn't work when you try a quick wash-and you see the water still dripping from the filter cap-then order another filter cap and not the child safety one with the clicking til closed.
Also make sure to keep the liquid softener fill area clean from hardened softener residue-use hot water and some vinegar-half and half and don’t overfill over the max level. Gently clean with tooth brush and thin cloth. Fill back up again this time turn on a on a quick wash cycle.
Clean the front washers inner rubber seal with a damp soapy cloth-remove any debris-clean any holes on within the lower bottom layers of the bottom rubber seal.
Punteggio 0
I fixed my leak using post about lining up groove and then I used pliers to tighten. No leak-very poor instructions in manual.Thankyou to Ifixit.com.
Punteggio 0
Thanks for all of these suggestions. On the third try/testing it out, it did finally stop leaking. You do have to GET ANGRY with it and push/twist clockwise as much as you can. Overall I have had good luck with Samsung products, but this is horrible. Fingers crossed it continues to function...
Punteggio 0
Aggiungi la tua risposta
Nikita Mart sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 17
Ultimi 7 Giorni: 138
Ultimi 30 Giorni: 616
Tutti i Tempi: 41,053
