Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1688/A1633. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 32, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
2690 Domande Visualizza tutte
backlight is on but No Image but phone works
I originally bought this iPhone with water damage saying that the screen won't turn on but phone works. I replaced the screen and the phone turned on and worked with iamge. But, recently, I had to replace the screen on the phone. When I tried to turn on the phone, the phone looked as if the screen turned on but the phone displayed nothing on the screen. Just the backlight. When I looked at the phone again, the connector for the second left one had a black mark on the 4th pin from the right(top). I was wondering if this is either from a Fuse burnt or if the phone has the backlight filter damage. I am not sure and I want some insight on this damage.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Probably backlight filter damage.
It's probably getting no backlight but image. You can confirm this by shining a flashlight on the screen and looking for dim display. E.g apple logo in middle when phone is turning on.
Punteggio 2
Aggiungi la tua risposta
bugattichi036 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 34
