Salta al contenuto principale
Strong, small, and stable, the Hubsan X4 107L is an excellent quadcopter for anyone learning to fly RC aircraft.
Is it safe to ultrasonic barometer
Hi , i have a hubsan H107D+ , which is flying erratically , i taken it apart and it looks like the previous owner had tried to oil the motors or something !! , there are 2 boards, a PCBA receiver board and a 5.8 GHZ TX camera module which seem to be covered in a fine oil !! infact theres oil all over it inside .
I would like to put the boards through my ultrasonic cleaner but the PCBA board has a barometer on it (see photo)
Barometer Chip
Is it a big no no to run a barometer through a cleaner ?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Well yes & no!
The chip when it was made had a cover over the vent hole so during the board construction debris or cleaning liquids won’t enter. But, now the cover has been removed so you can’t clean the board unless you reseal the hole and don’t use a cleaner which pulls the cover off (or leaks)
Their maybe other parts on the logic board that may need covering or removing.
Punteggio 2
Aggiungi la tua risposta
markparnell1972 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 15
Tutti i Tempi: 156
