Salta al contenuto principale
Dual-band, 802.11ac, 13-antenna router launched by Google and TP-Link in September 2015.
6 Domande Visualizza tutte
Why might my internet connection be slow?
I have a problem with my TP-Link TGR1900 (Google OnHub) router. My ISP gives me 250 Mbps. I have tested my service by linking ethernet directly to modem. It is good. At one point after I reset my router, my initial test was around 250 Mbps through the Google WiFi app. But when I tested again, it dropped to 30-40 Mbps. I have:
- reset router
- rest modem
- tried different ethernet cables
- disconnected my ethernet switch
Nothing seems to help. Do you have any good ideas or should I just buy a new router?
Update (05/18/2018)
Netgear 16-Port Gigabit Ethernet Unmanaged Switch, Desktop (GS316)
Questa è una buona domanda?
Punteggio 0
1 Commento
Hi Mark
Had you tried checking your router for any firmware fix?
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
Hi Mark
Good Day
Before you get a router, try this,
Check for any firmware updates on the router.
Connection Method
modem > router > Pc by wired LAN - (How much speed, e.g. from speedtest)
modem > router > Pc by wireless - (How much speed, e.g. from speedtest)
you mentioned there is ethernet switch ? if so what ethernet switch is it?
Punteggio 1
Do Internet Speed Test
Punteggio 0
Aggiungi la tua risposta
Mark Souverville sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 498
