Salta al contenuto principale
The Xbox One Wireless Controller model 1697 was released in 2015 and replaced the model 1537 controller and fixed some of the problems found on Model 1537 controllers. The Model 1697 controller includes an integrated 3.5mm headset jack, which allows compatibility with most 3rd party headsets without the need of an adapter. This controller has been discontinued and replaced by the Model 1708 controller.
75 Domande Visualizza tutte
Left bumper stays stucks until I click the right bumper
I recently bought a preowned Xbox One controller. Yesterday, I discovered that when I clicked the left bumper, it would stay down, as if were caught on something that wouldn’t let it click back into place. It only releases when I click the right bumper.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
The bumper seems like it is getting pined by some debris inside or, could be a bad momentary push button (clicker). The only way to see is to open the controller. Tutorial found here: https://www.youtube.com/watch?v=vc9c5qeE...
It's not difficult if you have the right tools:
-plastic spudger.
-torx screwdriver set.
-soldering iron (motor removals)
If it is a bad momentary push button, you'll need to solder a new button on which can be difficult and will need quite a bit of skill and patience.
Punteggio 0
Aggiungi la tua risposta
Avery K sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 226
