Salta al contenuto principale
A 21 inch HP flat LCD display.
Why have the buttons stopped working?
So the front buttons on this monitor have stopped functioning as normal. All the buttons including the power button only will activate the auto adjustment feature of the monitor except for the auto adjustment button its self.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi @tsallwasser
You will need to open up, and check on the buttons, for any dry solder joints or worn out micro switches on it. You can use the multimeter in beep community (digital) or resistance (analog) to test the microswitch.
depress the switch and it should beep, or the analog pointer will move.
https://www.youtube.com/watch?v=tYemeoqx...
Punteggio 1
Aggiungi la tua risposta
Tim sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 31
Tutti i Tempi: 1,577
