Salta al contenuto principale
Xbox One controller was introduced in 2016 with the launch of the Xbox One S and adds Bluetooth support for Windows 10/11. This controller fixes many of the design flaws found on the Model 1537/1697 controllers and is much more reliable. This controller has been replaced with the improved Model 1914 controller.
Xbox button not powering on controller
I just got a new Xbox one controller v2, but it won't turn on when I press the Xbox button.
When I connect the USB cable it starts and works just fine, I can even remove the cable once the controller is up and running and it maintains its connection to my Xbox. But as soon as I turn it of I need the USB cable to "jump start" the controller again.
The Xbox button and everything works as intended after I turned on the controller (with the cable), it just doesn't work as an "on switch" for the controller.
It is updated to the latest firmware and I've tried different batteries.
Questa è una buona domanda?
Punteggio 0
1 Commento:
I have this problem but my controller won't turn on at all
da
Aggiungi un commento
1 Risposta
Try a new controller. If it happens with that controller only, replace it.
Punteggio 0
1 Commento:
Thanks. The problem is just with this controller. But since the button works after I turned it on it seems like a software problem that could possibly be fixed (by a smarter person than me) without needig to replace it. Perhaps
da
Aggiungi la tua risposta
Marcus sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 4,638
