Wash load still wet-washer not draining and spinning properly.
The door to the washer was unlocked, but the load was still dripping wet. I hit the drain/spin button to spin it out again, but I got the Sud error code. I couldn't get it to clear until I unplugged the machine and plugged it back in. I tried the drain/spin button again and when the spin light came on, all that it did was fill with a little water (I could see it through the window) and make a noise. It did not spin.
Questa è una buona domanda?
7 Commenti
What's the code number?
da mayer
mine shows as F25
da Maggie Brink
We have a kenmore front load washing machine (model 110.47532601). Recently we saw an F 21 error code and we checked all the drain pipes and the filter for clogs. we didnt find anything. We tried the Rinse/Drain and spin cycle without the 2nd rinse and it works fine and it drains out all the water and dries up. But If we try to run any other cycle then it still gives us the F 21 error code. Can someone help in this matter?
Thanks
da Sam
My kenmore front loading washer is not giving any error messages, it runs till it says 1 min, then stays there for hours. The drum seems to move and it sounds like it's trying to drain but it never spins. I have tried just the spin cycle and it does the same thing. Any thoughts?
da Stacey O'Sullivan
I have the same problem with my Kenmore it washes but when it comes to drain and spin it won't spin I hear the water draining but not spin. It's also has the error on and all lights are flashing. Any thoughs?
da Alicia
Mostra altri 2 commenti
