Salta al contenuto principale
iPhone con schermo da 4" introdotto nel marzo 2016 con specifiche hardware simili a quelle dell'6s. Disponibile in Argento, Oro, Grigio siderale, Oro rosa con 16 o 64 GB. Modelli A1662 e A1723.
1049 Domande Visualizza tutte
iPhone Se Touch ID won’t work after screen replacement
Got my iPhone SE screen replaced yesterday with a reputable company. All was grand, no issue with the Touch ID until about an hour ago when it stopped working. Got a pop up saying unable to active Touch ID. Tried turning it on in setting and just said failed, try again. Restarted serval times. Is this a hardware or software problem and what could I do to fix it?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Check first all hardware, flexcables etc... check really detailes... also check the homebutton flex cable direction.... make clean with alcohol...
Punteggio 0
6 Commenti:
Aaa you not repair by self? Maybe the company forgot put small metal piece the homebutton flex conn... make reklamacion i think.... only touch id not work or complete button?
da
Only Touch ID, but was working perfectly until just over an hour ago
da
I got a year warranty on the replacement so I might talk to the company if I can’t get it to work
da
When you have warranty ask first this conpany for some solution.
. But dont open this iphone now... some service centre have some "warranty labels"... when you open it, he check it and warranty is finish.... but is 99% some issue abot the lcd change.... i think make no stress, you find some warranty solution...
da
I might bring it into an official apple distributor to see if it’s anything to do with the software and if they can’t figure it out I’ll send a message to the company
da
Mostra 1 altro commento
Aggiungi la tua risposta
Ciara sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 408
