Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1688/A1633. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 32, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
2690 Domande Visualizza tutte
Can someone help me with my iPhone 6s backlight
I have changed my screen I didn't disconnect the battery before I did it and the BackLight isn't working on the new screen. But when i put my old screen on its Completely fine.. I honestly need Help.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
You have done all the troubleshooting steps to properly identify that the problem is with the backlight circuit on the logic board. However, repairing the BL circuit requires a micro-soldering so unless you have the proper tools or experience, this is not a feasible DIY repair.
Generally, the problem is with the backlight filter (FL4211) but the damage can also extend to the entire circuit (U4020).
Your best bet is to find a shop that does micro-soldering in your area.
Punteggio 2
Aggiungi la tua risposta
DAngelo Latimore sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 59
