Engine leak oil also blows back oil from the dip stick
My car has an oil leak. It also blows back oil through the dip stick
Questa è una buona domanda?
Sounds like your PCV valve needs replacing.
mike vernon possibly blown piston rings. Check or replace your PCV valve as suggested and then do a leak down test. It will tell you a bit more about what is going on with your Camry
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 48
