Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1688/A1633. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 32, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
2690 Domande Visualizza tutte
No sound after screen replacement
I recently replaced the screen on an iphone 6, and now I'm having problems with audio. The sound on the earpiece works so I can make outgoing calls with no problem but there is no sound on the speakers ,or through the jack, and it doesn't vibrate. I tried a firmware reset but that didn't help, so I'm guessing I did something to the hardware when I replaced the screen. Any suggestions?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Might have ripped the charging port, check it for any tears. The loud speaker and headphone jack are connected to the port. Hopefully you removed the battery when you did the screen (so you dont blow up the backlight filter), in the process you could have damaged the port
Punteggio 0
I would recommend factory resting the phone or see if it needs an update.
Punteggio 0
Aggiungi la tua risposta
Jarret Nelson sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 884
