Hearing tv station other than what I am watching
Watching one station.
The audio through the headset is transmitting another station.
Questa è una buona domanda?
Hi @jmag18 ,
Is the 'other station' a channel on the TV that you can select? If so what do you hear then? The same audio as on the TV?
Have you checked that the headphones' base station is connected to the TV that you are watching?
Change the channel on the headphones base station (switch on base of base station) and then try re-tuning the headset to see if you can 'tune' into the channel you are watching in case the headphones are picking up an audio signal from something else.
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 65
