Salta al contenuto principale
The Kia Optima is a mid-size car produced by Kia Motors beginning in 2000 and marketed globally with various names. Firsts-generation cars (2001-2005) were generally sold as the Optima, though the name Kia Magentis was used in Europe and Canada when sales in those regions began in 2002.
50 Domande Visualizza tutte
Engine tries to turn over but does not. Especially when raining
After I washed my car the engine had a hard time turning over. After starting the car I did not have this problem until it rained recently. When trying to start either the engine tries to turn over or I get a clicking sound like the battery is dying. I believe I need to replace either the battery or alternator was wondering if I could get a more exact direction to go in.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
3 Risposte
Soluzione Prescelta
Take it to AutoZone or similar auto parts store and have them put a load test on the battery. They will do this for free. When batteries are dying they can have enough voltage but not enough amperage. The load test test them both. AutoZone also tests alternators for free. I believe they can do it while it is still in the car. You may want to call and confirm they will test the alternator with out you removing it.
Punteggio 1
1 Commento:
Good start. I would also check the cable connections between the battery and starter. +
da
Risposta Più Utile
try taking the alternator/distributor cap off and drying. I had this same problem following a thunderstorm. a quick spray with wd40 sorted the problem.
Punteggio 2
Take a multimeter and measure voltage on battery. If the voltage is less than 12.5V, you need to replace or recharge the battery.
Punteggio 1
Aggiungi la tua risposta
Daniel Snyder sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 20
Tutti i Tempi: 2,277
