Salta al contenuto principale
Rilasciato il 16 settembre 2016. Modello 1660, 1778. Disponibile come GSM o CDMA / 32, 128 o 256 GB / Rose gold, gold, silver, black e jet black.
2264 Domande Visualizza tutte
Unknown Diagnosis (iPhone 7)
iPhone 7 dropped dropped and worked however when it died it only charged to 3%. It was taken to repair shop where it I was taken apart and put back together and the screen showed saying connect to iTunes. I was given the iPhone, I changed the charger port, however it still showed connect to iTunes. When i connected to my pc with iTunes open nothing popped up however the iPhone charged. I disconnected the iPhone and it died so I went to charge it. When I came back 15 minutes later it would not turn on after hard resetting or force rebooting. Is this a logic board problem and where can I get this fixed?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
If you have a repair shop around your area that specializes in boards you can get a rough estimate from them. Otherwise I would probably just get a new device if you can. Seeing how that it will go into recovery mode (connect to itunes), the only data retrievable would be through the cloud. Of course, this is depending on the specialist for logic boards.
good luck
Punteggio 1
2 Commenti:
So this can’t be fixed? It cannot be restored?
da
It may or may not be fixable. This just depends on which part on the board was compromised.
da
Aggiungi la tua risposta
Christian Lapitan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 57
