Salta al contenuto principale
Lanciato a giugno 2012. Modello A1278. Processore Intel con Turbo Boost. Fino a 512 MB di RAM Video DDR5
1624 Domande Visualizza tutte
MBP is down Pulled the plug from my iPhone and than it crashed
My MBP 13" Unibody MId2012 chrashed.
What happened:
Connected my Iphone 5s to the MPB via cable.
I got called and pulled the Plug.
Screen went black... Thought nothing.
After the call i wanted to get working again... Nothing.
STATUS now
First the Macsafe Light was barley to see ... Color Green
My Macsafe now is blinking Orange, fast like 3 times a sec
The Batterylights on the Left show nothing.
The Powerbutton is not responding.
MPB is not starting
no Sound nothing
It is 2 1/2 Years old, never dropped, never spilled anything on it.
Weird... Last one i got ten years until the Battery exploded.
Maybe it was the Taxsoftware that make it chrash...
na just kidding
Any suggestions.
Logicboard? DC Jack? Everything?
Would like to fix it
I am tired of buying new stuff
Cheers
PS: I also speak German and Spanish, if this helps. ;)
Questa è una buona domanda?
Punteggio 0
1 Commento
I also tried 3 different Chargers. All react the same.
Flickering Light in amber/orange
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
The post: Not charging, blinking green/orange light could help.
Punteggio 2
2 Commenti:
Not quite sure about this, i read it some hours ago. But if the Ram reseat won´t work out. I´ll try something else. Thanks for the hint.
da
The Problem was solved by
- disconnecting the Battery
- with disconnected Battery i was able to power up the MBP via my MACsafe
Light was steady orange and bright
- turned of MBP
- making the SMCreset
- reconnected the Battery
works again
+ before that i reseated the RAM (2x8GB) as MR. MAYER recommended... so it didn't work straight away maybe it helped.
da
Risposta Più Utile
Reseat your RAM (three blinking lights).
Punteggio 2
3 Commenti:
Aye Aye Sir, i will try that.
Thank you very much
da
I reseated the RAM and Symptoms stay the same.
Powerbutton not responding
MACsafe Light on the plug flickering orange
No Chargeindication Lights
da
MR. MAYER thank you for your suggestion with RAMreseat.
da
Aggiungi la tua risposta
Jens Hindelang sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 70
