Idles to low after repairs
I recently made repairs to my 91 Camry 4 cyl including replacement of plugs, wires, distributor cap and rotor. It ran awesome for a couple hrs but is now idling to low and stops if I do not have the gas slightly pushed. How can I set the idle higher?
Questa è una buona domanda?
1 Commento
Did you by chance, twist the distributor ? The slightest tweek in spark timing would cause idle-speed to change.
Also check for a vacuum tubing not connected.
That being all OK, Remove the plastic air-intake to where you can see the throttle mechanism move when your helper steps on the gas. That thing has a easy-to-find-stop-screw for setting idle-speed. Turn it clockwise to idle faster. Stand to the side, have helper hold the brakes, put it in drive, and see how it idles.
Thats it - clean all the air intake parts while you have them off.
I had the big 6cyl toyota.
It had six pieces of plastic plumbing under the hood !
da Tom Shafer
