Salta al contenuto principale
Rilasciato il 16 settembre 2016. Modello 1660, 1778. Disponibile come GSM o CDMA / 32, 128 o 256 GB / Rose gold, gold, silver, black e jet black.
2264 Domande Visualizza tutte
Is adhesive for iPhone black and white same?
I have an iphone 7 black, And I want to buy an screen replacement adhesive for it. But the adhesive for black is not available , Can I buy white and will it fit as same as the black one?If for both it is same then what is the difference b/w the both adhesives?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
They are identical in dimensions, however the white one has white top and bottom bezels, so it looks better as light reflects inside the cover glass on the top and bottom.
Punteggio 2
2 Commenti:
So when i use this white one will the borders after install the screen look white?
da
There may be a little bit of color bleed, but in most situations it should not be very noticeable.
da
Aggiungi la tua risposta
Harsha Andra sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 232
