Salta al contenuto principale
L'aggiornamento di marzo 2015 del MacBook Air 13" di Apple ha processori di quinta generazione Intel Core i5 e i7, risultando in una migliore performance e maggiore vita della batteria.
623 Domande Visualizza tutte
MacBook Air not charging even after replacing magsafe port
My Macbook Air was not charging when plugged in (green light not coming on) so I replaced the magsafe port and it still wont charge. Sometimes if I leave the Macbook unplug for a few hours and then plug it in, it will charge. I've also reset the SMC & PRAM.
Update (03/26/2018)
I had the MagSafe plugged in and was lit orange as charging. I decided to try an SMC reset while it was actually orange lit charging. After doing the SMC reset. The orange light went out and now it won’t turn orange to charge again. It’s weird because I’ll leave the MacBook unplugged for hours and then try again to charge and it will turn orange.
Questa è una buona domanda?
Punteggio 0
5 Commenti
From my experience, SMC resets require a few tries - I've had to do it like 10 times at one point before it worked. Don't know how many times you tried it but worth noting.
da
based on my past experiences @brittkwa you are right there. probably something with the timing window you have being really narrow.
da
Hey Michael!
I have to ask, did you check and make sure the charge cord itself wasn't the source of the problem ?
da
I did. I used my sisters and it gave the same symptoms.
da
I have replaced the MagSafe port and the battery and the issue still continues. What could I possibly check now?
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
2 things are going on..
You either have a bad battery or a board issue
I'd try a new battery first but if that doesn't fix it, you probably have a issue with your ISL6259 charge controller on the motherboard. It can be fixed, but you'd need to find a shop that can repair motherboards.
Punteggio 2
5 Commenti:
My money is on the ISL6259 and the MOSFET
da
Did you happen to see my coconut battery screen shot? I believe my battery is good.
da
@danj Agreed... Which mosfet are you talking?
da
Near the battery connector
da
@danj Agreed.. Could very well be... @jdmikey83 Battery showing good in software doesn't mean much in this issue, try a new one
da
Aggiungi la tua risposta
Michael Hernandez sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 460
