Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1688/A1633. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 32, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
2690 Domande Visualizza tutte
Why is my iPhone making a white noise on snapchat, instagram etc
My iphone is not working when i was my iphone making this white noise like bery high when i take a video on snapchat and instagram and more apps? I just got the iphone 6s yesterday!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
5 Risposte
Risposta Più Utile
Hey Cindy! Could be a couple things. Take a video outside of the apps with your front camera and see if the noise is there.
Likely culprit is the top microphone, which is an easy fix. If the phone is refurbished, or sold by a third party it's easy to miss that during testing. it COULD also be software related. Unlikely, but you can try a quick update and see if that changes anything.
Punteggio 1
5 Commenti:
Mine makes white noises too but only on insta, snapchat not the icamera... works on both front and back mic
da
I have this same problem only when recording on IG. Did anyone get a solution here?
da
I have this same problem only when recording audio on IG. Does anyone have a solution yet?
da
My phone is a replacement phone that I’ve had for less then 30 days and I’m having the same issues. There is no static sound on the camera app front or back, but there is on Instagram and Snapchat.
da
I have this problem on Tiktok,Snapchat,Instagram. When I dont have my AirPods in during a phone call or FaceTime the same thing happens. And without my AirPods my camera picks up my microphone no problem. I need help!
da
The phone I had was a refurbished phone from AT&T. I spoke with them on the phone and was able to get a replacement phone that did not have this failure. Restarting the phone and erasing the application and redownloading did not solve the problem. It was the phone itself.
Punteggio 0
You try it for me once, uninstall those apps and install them anew.
Punteggio 0
its the dirty mic. i have an iphone 7 and it has little holes at the bottom that receive the sound. get a needle or a thumbtack and scrape the moist dirt thats stuck in there. i did that and it started working like magic
Punteggio 0
This might be due to some dust or sensor. If the problem remains then download gbwhatsapp apk and install it on your iphone.
Punteggio 0
Aggiungi la tua risposta
cindy sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 104
Tutti i Tempi: 19,896
