Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1688/A1633. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 32, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
2690 Domande Visualizza tutte
Service Provider in settings keeps appearing and dissapearing
This phone has been previously liquid damaged and cleaned very well on the logic board.
Now the leftover issue is:
Service Provider option in settings keeps appearing and dissapearing, phone sim card detect fine, goes searching then no service.
IMEI and modem firmware displayed in settings, checked *#06* no problem there too.
Is it okay to reflow the U_WTR_RF transceiver chip because of liquid damage before? Maybe it'll fix the problem?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
If the IMEI is showing, then the problem is not the usual long-jumper Baseband repair. You could try to reflow U_WTR_RF but I would probably reball it instead. You could also look at U_ASM_RF & U_WFR_RF. @teetopp summarizes it well in this answer (Service is "Searching" indefinitely).
Punteggio 3
Aggiungi la tua risposta
Ben sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 125
