Salta al contenuto principale
A powerful workstation laptop that fits into a portable package. Has multiple ports and connectors for a portable work environment.
7 Domande Visualizza tutte
Is upgrade to m2 ngff ssd possible?
Hi,
I have an hp 8740w. I want to add on it another m2 ngff ssd 32gb to install on it linux, to not touch the main drive.
I want to know if this will be possible, considering that i will use ngff m2 to pci-e converter.
I also want to know if there is any way to install it full separately and not touch the windows mbr.
Lastly i want to know how safe is to use this converter for the laptop logic board?
The converter is that here:
https://www.ebay.com/itm/New-M-2-NGFF-SS...
Thanks in advance!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Your system has a standard 2.5" SATA drive. Where where you planning to install the M.2 drive?
Here's the service manual EliteBook 8740w
Punteggio 3
9 Commenti:
Thanks @jayeff - corrected!
da
Hi @danj ,
All's good.
Cheers.
da
Thanks for your answer
I plan to install it on mpcie slot that have the WWAN 3G modem. And I find the adapter above. I also have already install a bigger ssd for my main OS , but i need separate ssd for the Linux. I read and this slot is mpcie, but i cant find anywhere if the adapter above is legit and safe to use.... I want to install m2 ssd 32gb that I randomly buy.
da
It likely won't work as the systems BIOS does not treat the slot as a generic PCI slot. Besides the phyical size of the adapter & SSD will exceed the space location the modem takes.
You do realize you can partition a HDD or SSD with multiple partitions which can support different OS's then using a boot loader to offer a means to select which OS to boot up makes more sense.
da
Yes , but this will update my MBR... I want to have it on another physical drive to not be single point of failure.
I will go with plan B and remove the dvd and install SSD :( . I like to have the dvd here! Then I will try to install Clover or Refit on that to check if will work. I hope that will work....
da
Mostra altri 4 commenti
Aggiungi la tua risposta
ssavva05 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 2,826
