Salta al contenuto principale
The third generation of the Toyota Camry in all markets outside Japan. 1991-1996 was also called the XV10 series of Camry vehicles.
79 Domande Visualizza tutte
Pull the engine to replace a timing belt on a 1991 Camry?
Do I have to go as far as removing the motor to replace a timing belt on a 1991 Camry? Anyone know of a good website I can download a repair manual for my car, for free?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Does not read like you have to remove the engine, but definitely the engine mount on the right. Not a fun job but doable...besides the advise that ABCellars gave you here is another website that has some info
Punteggio 2
No, you don't have to remove engine. It's sufficient to hold engine with jack and block of wood underneath oil pan. Shouldn't be too much of a hassle...
Punteggio 0
Aggiungi la tua risposta
Jesse sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,047
