Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1688/A1633. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 32, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
2690 Domande Visualizza tutte
6S No charging symbol, still charging up but not past 11%
Hi there, this is my first time posting on iFixit as I've run into an issue I haven't seen before.
I have a customers iPhone 6S which isn't charging, I've tested charge port and battery to no avail, and also tried device in a known good housing assembly.
The device charges with no charging symbol or sound, however it only charges up to 11% (roughly) and stops. I left it on charge overnight and arrived one morning to find it on 6ish%, hence my confusion.
Would this be tristar? How would I know, and what can I test to find out?
Device has not been water damaged, and came in for a screen replacement initally.
Have done a mainboard inspection and can't see any obvious burns or damage.
Kind regards,
Silas.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
If you can't get Apple logo with battery unplugged and charger plugged in then Tristar is bad.
Punteggio 2
2 Commenti:
That's an incredibly helpful peice of information. Thank you.
da
So what what it? This is my problem on my phone right now.
da
Aggiungi la tua risposta
Silas sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,989
