Salta al contenuto principale
Lanciato a giugno 2012. Modello A1278. Processore Intel con Turbo Boost. Fino a 512 MB di RAM Video DDR5
1624 Domande Visualizza tutte
Having performance issues after cloning drive.
When I cloned my old HDD is (high sierra) to new Samsung 860 EVO 500 GB SSD and Insert it back into my MacBook Pro 2012 i5 2.5 GHz Sometimes it works great but sometimes my system gets stuck and does not respond.
Now tell me which cable do I need to purchase for this purpose and is it compatible for my system.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
You likely have two issues here the first is cloning is not such a good idea! Many cloning apps don't setup the recovery partition and you likely need to apply some firmware updates which only happen when you do a full OS install.
The second issue is as you described your HD SATA cable is likely worn. This is a common aliment as the uppercase surface is a bit rough and can damage the cable.
First I would replace the cable following this IFIXIT guide: Sostituzione Cavo hard drive MacBook Pro 13" Unibody metà 2012 and here is the part you'll need: MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable. Where the cable crosses the upper cable place a strip of electricians tape to help protect the new cable.
You'll need to make an OS installer to first delete the current partitions so you can re-do them using the OS installer drive to boot up your system. Here's the guide you need to follow: How to create a bootable macOS Sierra installer drive Now before you jump on me I don't recommend going with High Sierra with SATA based SSD's! Apple still has some issues with queueing. High Sierra was tuned for PCIe/NVMe SSD's. So please do your self a favor stick with Sierra until the next release this fall which is when I'm hoping they fix things with APFS.
OK, You've setup your SSD and installed a fresh OS on it now we want to bring your stuff over. This is where you can use Migration Assistant to move the user accounts, apps & user data from your old drive. You want to use Migration as it will fix and damaged files from your bad cable you had with your HDD.
Immagine MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable
Prodotto
$34.99
Punteggio 0
Next time use time machine backup
Punteggio 0
Aggiungi la tua risposta
CHANDER SHARMA sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 61
