Salta al contenuto principale
Device and repair guides for the RCA 10 Viking Pro, an Android tablet with detachable keyboard that can be identified by model number RCT6303W87 DK.
Reset windows installation error
I did a factory rest on my tablet and every time it tries to restart and reinstall windows, it throws an error message that says “The computer restarted unexpectedly or encountered an unexpected error. Windows installation cannot proceed. To install windows, click ok to restart the computer, and then restart the installation.” When I choose “ok”, it cycles back to the same error message. What do I do?
Questa è una buona domanda?
Punteggio 1
2 Commenti
Windows? This is an Android tablet! How on earth did you get Windows on here?
da
I keep doing the same thing,what I do when if Occur
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
1) On the same error screen press SHIFT+F10 and it will open up a black Window. (a command prompt window)
2) In  the black windows type the word "regedit"(without the inverted commas and hit enter. That will open the registry editor.
In the Registry Editor..
Browse to....
HKLocal machine/SYSTEM/SETUP/STATUS/ChildCompletion, and after highliting childcompletion,on the right hand side check for setup.exe. if the value is 1 change it to 3.(by double clicking on setup.exe and changing the value shown in the box).
Then close the registry editor and then also close the black window.
Then click on OK for the error and the computer will restart and the installation may complete.  try it and if the installation failed, check out these methods.
Punteggio 6
7 Commenti:
how do i pres the SHIFT +F10 because the is no keyboard display
da
usb keyboard worked for me:-)
da
Thank you Albert. it worked for me on Surface 7.
da
Thank you so much, worked instantly!
da
It goes to loading screen at 64 % than restarts been doing it for several hours
da
Mostra altri 2 commenti
I think this fix also worked for me. Windows is installing its at 44 percent. Hopefully it keeps going!
Punteggio 0
Aggiungi la tua risposta
Chrissy sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 4,282
