The low beams on my 2014 Accent aren't coming on.
A few days ago, I replaced the bad bulb on my headlights. Today, after working for the last few days, I noticed that the low beams are not working. The high beams are working, and everything else seems fine. It is only the low beams that are not. I checked the fuses, they seem to be fine, as far as I can tell.
What could I do to fix this?
Questa è una buona domanda?
5 Commenti
i have the same problem too, on my hundai accent projector lamp…either you put the switch at low beam or high beam, it’s just the same(it’s always giving the high beam), the light that is emitted is at high beam …the problem really here is that, the bulb doesn’t have anything that will put the light into high(making it brighter) because there is only one filament.. actually, the projector lamp has a motor which twist/move the bulb to high and low…it doesn’t really gets bright.. it only change the trajectory of the beamed light. I think, the motor is still in good condition, only that it has a gear which is made up of plastic, which i think has run out of thread, that’s why even if the motor tries to move the trajectory of the beam light, it won’t move because of the problem on gear…I hope Hundai, will give us the solution to the problem..
da Nicolas Diaz
i already tried swapping the two relays, but didn’t work…the light beam is consistently at the high beam…the two relays seems ok… you can hear the click sound on both… but the motor on the bulb doesn’t respond. thank you..
da nickskie0507
I just have one low beam not working is it a fuse too
da lady5417
I just have one low beam not working is it a fuse too the driver side
da lady5417
My projector headlights only have high beams..
da probiker
