Salta al contenuto principale
The Kia Sportage is a compact SUV built by the South Korean manufacturer Kia since 1993.
Red Downhill Light Dashboard
Why is the downhill light on the dash lit on?
Questa è una buona domanda?
Punteggio 2
4 Commenti
Same problem with Hyundai x135
da
i had this issue, solved it by changing the switch on the clutch pedal. Not the easy access one but the one tucked up high and difficult to get to. the switch is about £40 form Kia. Took 20 mins to fit
da
You will fine the speed control would not be working at the same time
da
Also Replaced the top clutch switch on my 2015 Kia Sportage and the issue was resolved.
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Hi,
Have you pressed the Downhill Brake Control switch on the dash to see if the light goes out?
The following image is taken from the 2012 Kia Sportage owner manual. (You didn't state the model year so the switch may be in a different location)
(click on image to enlarge for better viewing)
If operating and releasing the switch makes no difference and you have traveled faster than 40 m.p.h. and the light is still on, then the DBC system may be faulty. Take it to a dealer and get it checked out.
Punteggio 3
2 Commenti:
had it at the dealer and they cant fix it.
da
Hi,
If the dealer can't fix it (or doesn't know how to) contact Kia in your country and ask what the problem could be or contact another dealer.
They should have the service manuals and equipment to diagnose what the problem is, more than anyone else.
da
Hi @ chris mc millan
Here’s some images taken from the iX35 owner manual that explains how to use the DBC (Downhill Brake Control) and how it can be manually activated etc.
If it isn’t manually enabled by you operating the switch then you need to take it to a dealer as they should have the service manuals and equipment to diagnose what the problem is.
Punteggio 0
Aggiungi la tua risposta
Abraham September sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 38
Ultimi 30 Giorni: 182
Tutti i Tempi: 20,252
