Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1687/A1634. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
1041 Domande Visualizza tutte
NFC reader not working after replacing battery.
Just noticed that my nfc isnt working when trying to use apple pay. I replaced the battery myself last week so Im assuming I damaged something during the process. What should I start with checking or replacing? Thanks
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
You may have inadvertently damaged or not re-assembled the NFC bracket next to the Screen Bracket. Check out this guide, specifically steps 30-31.
Punteggio 1
1 Commento:
Just opened phone back up and inspected that area, I didnt see any issue with it I definitely hadn't messed with it when I changed the battery. Have you heard of people needing to replace the nfc bracket after a battery change?
da
I had replaced my iPhone 6S Plus battery (2750 mAH) with that of 6 Plus (2915 mAH) since both have the same connectors. Battery life did slightly increase but at the expense of the non-functioning NFC/Apple Pay. I think it might have to do with the overclocking of the NFC frequencies out of the acceptable spectrum .
I thought the slightly longer battery life wasn’t worth the lack of NFC so I installed the correct one for iPhone 6S Plus battery (2750 mAH) and NFC/Apple Pay is working well afterwards.
Punteggio 1
1 Commento:
I had the same issue on my iPhone 7. After replacing the old battery for a new one with much more capacity (1800 vs 2100 mAH), the NFC stopped working.
I will try to replace back a 1800 mAH battery again in the future, and let's see if the NFC works well again.
da
Aggiungi la tua risposta
Chad sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 23
Tutti i Tempi: 3,588
