Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1688/A1633. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 32, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
2690 Domande Visualizza tutte
iPhone 6s face camera " foggy "
Hello everyone here is the thing my face iphone cam is foggy compared to other iphone 6s (watch the pictures)
Then i just saw that i had like dust in the front of my iphone like between the glass and the lens i can see it it's not all black there is like dust inside, im not a phone technician or something, but a computer one so i know how to open things etc
my questions is can i open the iphone and clean it inside ? like here inside this little thing : https://imgur.com/GKUDryR
Photo comparison between my iphone 6s and a friend one : https://imgur.com/a/g0im7
what can i do guys ?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
absolutely.
Removing the screen, and there is a casing at the top with 3 screws.
Remove that, and your earspeaker and camera should pop right out. then you can clean the camera lens
Punteggio 1
2 Commenti:
How can i remove the screen ? any guide on it ? thanks for the fast answer mate !
da
Sostituzione schermo iPhone 6s
this guide should show you how to get far enough to clean out the lens
da
Did you ever soak it in alcohol?
And if its new, you can get it replaced for no cost.
Punteggio 1
2 Commenti:
Not a new one bro, should i soak it in alcohol xD ?
da
No, I said that because its a CAUSE for a screen to be damaged. I looked it up, and you should never soak it in alcohol because it causes screen issues.You want it dry, not to soak it in liquid again XD
da
Aggiungi la tua risposta
Georgie sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 4,046
