Salta al contenuto principale
Informazioni sulla riparazione e guide per l'iPhone 8, lanciato il 22 settembre 2017. Modelli A1863, A1905.
873 Domande Visualizza tutte
Hard Reset Not Working
I know on the iPhone 8, you must hit the volume up button, volume down button, then hold the side button until the hard reset begins. I cannot get this to work -it only gives me the option to shut the phone down normally. What should I do? The phone is new and has no other issues.
Questa è una buona domanda?
Punteggio 9
15 Commenti
I had the same issue as Jack. I held the right hand button for ages and it only gave me one option, to shut down. I also tried to reset the phone using Find My Phone which was another option but that only works when the phone logs into the internet. If the phone is disabled, this doesn't seem like a good option.
da
When the phone is disabled the only option may be to reboot it into recovery mode with the use of 3UTools.
da
@jack35
@amalkaru
@ben
So you press volume up and volume down as you have done. Then press and hold the power button.
The power off slide bar will appear,you simply HOLD the power button down until the Apple logo pops up and then release it.
So you hold it down approx ten seconds without sliding the shutdown bar. The screen will go blank but it then goes to white screen with Apple logo and you release and then it does it’s reset!
Below shows what I have commented.
Best of luck . Any issues just mail me.
Ryder
https://appletoolbox.com/2017/09/forced-...
da
I’m attempting to clear a bunch of emails that are dated 12/31/2069 that are blank and won’t let me move or delete them. The suggestion was to do a hard reset. However, when I try to follow Ryder’s suggestion, my phone dials emergency services! How am I to do a hard reset?
da
Try making sure you hit the volume buttons in quick-enough succession. The phone seems to be very touchy about speed, and you must be very fast. And don't hold down the volume buttons at the same time as holding the power button - I think that's the combination for calling emergency responders.
da
Mostra altri 10 commenti
Aggiungi un commento
4 Risposte
Soluzione Prescelta
It does take time for it to restart itself. If you hit the Vol Up, Vol Down, and Side Key fast enough you will see the Shut Down *do not* lift your finger off the side key and after 15-20 secs it should shut down.
Punteggio 12
11 Commenti:
@juax that did the trick! Thank you! Can we vote to make this the answer? It was very helpful. Thank you!
da
You're very welcome. I believe you have to select his answer as the selected answer for your topic.
da
Thank you!!!!!!!
da
For some reason my phone isn’t rebooting at all. It will shut down and the apple logo with show up, but then the phone just turns on and asks me for my password. What am I doing wrong .?
da
thanks. it's really works for me
da
Mostra altri 6 commenti
Come forzare il riavvio dell'iPhone 8
keep holding until you see the apple logo.
Punteggio 2
12 Commenti:
I tried this again and it did not work. It either gave me the regular shut down switch or did nothing.
da
you sure you've held it down long enough?
da
actually instead of pressing volume up and down at the same time, seems you press the volume up and then the volume down button https://www.macrumors.com/how-to/force-r...
da
I’ve tried both ways and neither seems to work.
da
Also have the exact same issue. @jack35 did you find a solution?
da
Mostra altri 7 commenti
Well, I’m having a similar problem. I’ve tried all the suggestions and still nothing works. My iPhone 8, Plus, will not hard restart, soft restart, etc. Nothing works. I’m waiting for it to shut down when the battery runs out. Hopefully that will do it when I recharge.
Punteggio 0
1 Commento:
I now have the same problem, did you manage to fix this?
da
I have the black screen of death. It won’t turn on even after all suggestions. The computer doesn’t even detect it when I plug it in. I’m not even done paying it off and it has decided to die on me!
Punteggio 0
3 Commenti:
Try holding down the power button and while holding the power button in plug your device into a computer with iTunes on it and wait to see if iTunes picks up your phone in recovery mode or comes up with the message to plug your device into iTunes. Once you see any of these you can then let go of the power buton. If there is any power going to your board then it should go into recovery mode which should allow you to restore the phone. If not you will have to take it somewhere that repairs iPhones as they will need to open the device and try figure out the problem.
da
Same here . Hold power button down until finger is numb and will not show Apple logo only Slide to power off . Tried numerous times . Wish I had Kept my iPhone 7 this 8 is a pos
da
What if you have no computer
da
Aggiungi la tua risposta
Jack sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 43
Ultimi 30 Giorni: 177
Tutti i Tempi: 131,868
