Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1688/A1633. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 32, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
2690 Domande Visualizza tutte
iPhone 6s battery smell
When I was replacing the battery of my iPhone 6s the adhesive strips broke. So as the ifixit guide suggests I tried to use dental floss along with the tools in the kit to pry it out. I thought I almost had it when I started smelling something coming from the battery, at this point I stopped immediately and placed it in the other room. What should I do?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
5 Risposte
Risposta Più Utile
Either get someone to remove the battery for you or you will have to end up prying it out.
Punteggio 3
1 Commento:
Or just take it outside?
da
Hi
Sorry to ask did u disconnect battery from motherhood.
If not disconnect battery first.
Remove Lcd from phone.
Now take some plastic card like playing card and put it under battery from left side of phone and slide it slow under the battery. And don’t use any metal thing to take out battery.
In this way u can remove battery safely.
Always use safety gears.
If still not confident better to go to some repair store.
Regards
Phone beats
Punteggio 2
6 Commenti:
Yes everything's removed and disconnected
da
I am mostly concerned about the smell
da
I think smell is due to when to cut outer black layer of battery.
Don’t try to take battery with any metal thing. Remove it with plastic playing card.
Again if you really not confident better to go to repair store.
Regards
da
Please keep spam out of your answers. You can advertise phone beats in your profile page.
da
@captainsnowball this one too:
What does it cost to replace the glass?
da
Mostra 1 altro commento
Lol when I read the question I was like 'Wait why are you smelling the battery?' XD
Anyway, the battery might be corroded or leaking.
Punteggio 0
4 Commenti:
Honnestly had the saaaame issue and got scared quick cuz you always here about batteries exploading so when i started smelling a sweet toxic smell i just immedietly pried it out to avoid ruining the phone and it worked. Now im about to install the new battery
da
Lol...At least you got it taken care of.
da
Haha yeah about that, i apparently ordered a ifixit iphone 6 tool kit battery replacement.... I have an iphone 6S soooo when i was trying to install the battery to my surprise wouldnt fit, because iphone 6 and 6s are not compatible, huge blow i needed my iphone this week and now Iphone6S batteries are out of stock, if you happen to know how to help before tomorrow 15:00pm EST id be glad to order another online.
da
use a hot air in the back of the iphone (not very hot) the glue under the battery will be more elastic and you can remove it without problem
Punteggio 0
1 Commento:
60°C / 140°F to be clear. 80C is okay too if it's not hot enough depending on how hot it is in your area.
da
Probably your battery has a small hole . But I recommend to change your battery.
Punteggio 0
Aggiungi la tua risposta
Trey johnston sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 4,506
