Salta al contenuto principale
Rilasciato il 16 settembre 2016. Modello 1660, 1778. Disponibile come GSM o CDMA / 32, 128 o 256 GB / Rose gold, gold, silver, black e jet black.
2264 Domande Visualizza tutte
Is there any way to see if the homebutton is original?
Hey, is there any way to see if the homebutton is original?
Got one that dosent work but i dont know if they replaced it before so it dosent work because of that.
I also got one that I do know is original.
Components looks the same, the qr code dosent.
and numbers on the flex is:
821-00912-02
MFC3116
dont know if that one is original.
The one I know is original says:
821-009
MK12-02.
Thanks for any ansers.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
To be blunt does not matter if it's original or not.
The only home button that will ever work on an iPhone 7 and higher is the same home button that came with the phone.
Punteggio 0
1 Commento:
That I do know, and i do not think they took an other iPhone 7 original homebutton so they screwed two phones.
Bought it water damaged and dead, and have fixed that and there is not any other damage on the board, and they have made a little damage on the homebutton flex, the little one after the "u10" ic, but the homebutton dosent work at all so thinks it's an copy. Want to be sure doh
da
Aggiungi la tua risposta
Jonny sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 780
