Why is my alarm going off late?
Since my phone updated around January 19, 2018, my alarm has gone off 4 minutes late on more than one occasion. This would not be a big deal except that it is unpredictable and affects my "get up for work" alarm throwing my whole morning routine into chaos. I have checked to make sure that the proper time was set -which it was. (By the way, the way alarms are set in the new version of Android is obnoxious).
Questa è una buona domanda?
Hi @mimamu ,
What setting have you selected in Settings > date and time?
Automatic date and time or are you setting it manually on Set time?
da jayeff
I think automatic date and time. I don't recall changing it manually.
da Victoria Masters
Hi @mimamu ,
Does it keep the correct time normally?
You said that it was late on more than one occasion not on "every" occasion.
Wondering if perhaps you should disable automatic date and time and automatic time zone and set the time/date/zone manually and see how it performs.
Perhaps the time signal from your provider is somehow glitching the time.
Only way to find out is to disable it and see.
da jayeff
It does keep the correct time normally. I will try disabling the automatic date and time and setting it manually.
Thanks for the suggestion!
da Victoria Masters
Same problem since January update. I have tried with automatic date and time set to on and set to off. Doesn't make any difference. Alarm goes off 4, 9 or 14 minutes late. Any other recommendations
da RODNEY CURTIS
