Salta al contenuto principale
The following information is intended to help service the Nerf N-Strike Elite Strongarm . The Strongarm was released in 2013 by Hasbro under their Nerf brand.
Why won’t my barrel turn after I shoot
I had my strong arm for a while and I can’t figure out why when I shoot it the barrel won’t turn and also it creates a loud sound when I shoot it. Very rarely would the barrel turn when I shoot, what should I do?
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
It could be that the gears are slipping or worn out
Punteggio 0
2 Commenti:
Should I open it check for a problem?
da
Ter ar please u can send it to that can fix it but unles u hav the rite gier u won’t be abol to fix it
da
Mine was doing this, and it turns out that the gears were fine, but a screw post that holds the gear assembly together had split such that the assembly was slipping.
Attempting a repair with epoxy, but expect to have to find parts somewhere, or build a new mechanism.
Punteggio 0
Aggiungi la tua risposta
Christine Berry sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 13
Tutti i Tempi: 848
