Salta al contenuto principale
The VLT 1000 desktop fan has four blades with a diameter of 30 cm. It is made of stainless steel and has 3 speed settings.
18 Domande Visualizza tutte
Delonghi Desk Fan - tear down assistance
I have one of these that is about ten years old and there has been a build up of friction from dust or perhaps a lack of lube. Was breaking this down for a clean and lube / oil but cant seem to figure out how to remove the swing control knob. It is the last piece to the puzzle for removing the motor and bearing housing. I have tried to unscrew it both anti-clockwise and clockwise (which only seems to unlock / lock it to the swing motor shaft. as you would expect), but it seems to be held in by something else. There are no screws or bolts visible and I have had a feel around for a circlip but doesn't seem to be one (and no room for one really). Has anyone got experience with these fans and have an idea how to remove? thanks
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
You just need to pull hard to dislodge it.
Update (02/02/2018)
Only the circular spring is holding it in place.
Here is how the knob and oscillating assembly look like inside.
Punteggio 4
1 Commento:
Perfect, thanks!
da
Aggiungi la tua risposta
Mr Fix sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 43
Tutti i Tempi: 1,186
